Evildaddy's avatar
Evildaddy
Nighthawk XR500 Blocking Adventure Academy
My Nighthawk XR500 is blocking Adventure Academy from connecting to the server. I was able to verify this by bypassing the router and connecting my PC directly to my modem and the game connected with no problem. How can I rectify this issue?
  • FURRYe38's avatar
    • Evildaddy's avatar
      Evildaddy
      The current firmware version for the Nighthawk XR500 is V2.3.2.56. I purchased the modem from amazon. It is a Netgear CM700. I doubt the modem has anything to do with the issue because when the PC was connected directly to the modem, bypassing the wireless router, I was able to play the game with no problem. I play MMOs and all types of other games with no issue. This is the only game I have experienced this problem with.
    • Netduma-Fraser's avatar
      Netduma-Fraser
      NetDuma Partner
      Are you using the Geo-Filter at all for the device? If so remove this, does that resolve it? Otherwise are you using Traffic Prioritization?
        Evildaddy
        I dont believe geo-filtering is being used. When I navigate to the geo-filtering window there are no devices above the "Add Device" button. When I navigate to the QoS window, I have tried unchecking the All Devices -> DumaOS Classified Games check box, still no change.
