MoonToast
Jun 01, 2021Aspirant
Nighthawk xr700, DumaOS not loaded yet
Hello, i have recently gotten this message since last Friday and i have tried rolling back the firmware and the other solutions for the XR500 and none have worked for this.
I can not set up a wifi signal, when i do it shows the DumaOS not loaded yet page.
Please could someone help me, as i need this working
- Netduma-FraserNetDuma PartnerFirst try clearing the browser cache/cookies, then try accessing using the Microsoft Edge browser, if it still doesn't work a reboot should fix it.
- MoonToastAspirantHello, i have tried what you suggested and i have the same results. I have tried rolling the firmware back and that also didn't work.
I have tried multiple different browsers same results.
I have tried everything on the forums for similar issues of other devices and they too have not worked.
This seems to be a recurring problem for the xr routers.
What do you suggest i do?- Netduma-FraserNetDuma PartnerRe-install the firmware using the TFTP method then factory reset after it's finished the upgrade (so 2 minutes after completion) then see if it works, may be the upgrade was corrupted.
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
- walhusAspirant
DumaOS not loaded yet!
Don't worry we will redirect you shortly.
I get this message every time I attempt to update my xr700 router. I've tried a 30-30-30 reset dozens of times. I've tried to install every image, including the beta releases. I've submitted this to Level 3 support at Netgear but they haven't replied to me after 5 days. I've offered to send the router itself to Level 3. I purchased a Gearhead support contract. Nothing seems to work. I can get in to the router with routerlogin,net/adv_index.htm and it does support ethernet connections to the internet. Wifi fails. Does anyone have any suggestions as to how I can get past this impasse or get through to Level 3 at Netgear?
- Netduma-FraserNetDuma PartnerAll that should be needed is a reboot from the interface - wait 2 minutes before accessing/connecting and then try and see if it works.
- walhusAspirant
I've tried rebooting from the interface without success. I've spent hours on the phone to gearhead support. I'm now trying to TFTP all the images to the router. I get internet access from it but no DumaOS and no wifi. It's very frustrating. And I don't like giving up.
- walhusAspirant
DumaOS won't install on my XR700 yet it still gives me an ethernet connection with no wifi and a skeleton interface that let's me install images.
I have tried every single image to restore my XR700.
I have tried the tfrp method
I have tried 30-30-30 resetting it
I have tried purchasing gearhead support
I have escalated to Netscape Level 3 support (THEY WON'T REPLY)
I have tried EVERYTHING I've read in these forums.
I'm up against a brick wall here.
I need an out of the box solution
Any ideas?
(The attachment is the frowning square face screenshot I get right after I get my configuration complete during the install process and it goes downhill from here)
