Mrpenguinz's avatar
Mrpenguinz
NightHawk XR700 GAMING ROUTER R-Apps not loading.
It's now 2022 I'm still having same problem that is "This R-App is not loaded yet, please try again in a minute." None of the R-Apps ever load Geo - filter, Qos, Device Manger, Network Monitor, Hybrid VPN. I've also done the whole changing the retry amount from 3 to 5, still doesn't work. Does anyone know what causes this problem?
My Current Version: V1.0.1.48 and when I check for updates the router says I can update to New Version: V1.0.1.48
Thanks for any help.
    • Paulgins's avatar
      Paulgins
      Do you have good solution and excellent feedback for R-Apps not loading? Because 'trying beta 3.0' with factory reset is the last thing i would like to 'try'.  Unless you are sure that issue is solved.  Or is Beta enough tested after two years having this issue.
      It's pain full.
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        A more permanent fix is coming with the next firmware version, the suggestion above or going to the System Information page and then clicking on Rapp panel menu (≡) and changing the retries to 5, then rebooting from the interface and waiting 2 minutes before accessing are the best options currently.
