Imitable's avatar
Imitable
Nighthawk
Anyone else having any problems trying to change the nat type from strict to open?
  • plemans's avatar
    What problem are you having?
    What router are you using?
    Firmware on that router?
    What modem are you on?
    Maybe explain exactly what you're trying to do and why you're trying to do so. This will let us to help you better.
    • Imitable's avatar
      Imitable
      The router I am using is the AC2400 and the modem is the AC1900
      The problem that im having is that when I try to play any of the call of duty games my NAT type is set to strict instead of open.
      • plemans's avatar
        Neither of which are model numbers. But from the sound of it you're in a double nat. Is the router in ap mode or the modern in passthrough mode?
