TwistedVet's avatar
TwistedVet
No Internet
This may have been anwsered before but I couldn't get a search result to assist me. I just bought a XR500 and cannot get a connection to the internet (no LED) showing. Spectrum ISP w/ en2251 modem
- Factory reset router
- I have access to Netduma
- Updated Fireware to V2.3.2.114
- no IP address
- reset my modem
- I have internet if I plug into my modem
- I've tried different cables (new)
- Restarted both modem and router at the same time, then modem bofore router and router before modem.
- I am not getting any port lights off the modem when i plug into it from the router but i do when my computer hooks up.
  • [admin login] from source 192.168.1.2
    [DumaOS] Ubus object 'com.netdumasoftware.geofilter' added, attempting to bind pending
    [DumaOS] Ubus object 'com.netdumasoftware.hybridvpn' added, attempting to bind pending
    [DumaOS] Ubus object 'com.netdumasoftware.devicemanager' now bound
    [DumaOS] config write 'com.netdumsoftware.geofilter.settings'
    [DumaOS] No settings file, restoring.
    [DumaOS] Geo-Filter cloudsync result 'false','All mirrors are down'
    [DumaOS] Ubus object 'com.netdumasoftware.rappstore' added, attempting to bind pending
    [DumaOS] Ubus object 'com.netdumasoftware.qos' added, attempting to bind pending
    [DumaOS] Ubus object 'com.netdumasoftware.devicemanager' added, attempting to bind pending
    [DumaOS] Ubus object 'com.netdumasoftware.desktop' added, attempting to bind pending
    [DumaOS] Ubus object 'com.netdumasoftware.dpiclass' added, attempting to bind pending
    [DumaOS] Ubus object 'com.netdumasoftware.autoadmin' added, attempting to bind pending
    [DumaOS] Ubus object 'com.netdumasoftware.neighsync' added, attempting to bind pending
    [DumaOS] App 'com.netdumasoftware.rappstore' initialised & starting.
    [DumaOS] R-App store cloud sync failed
    [DumaOS] HTTP download failed with code 'host or service not provided, or not known'
    [DumaOS] applying qos for zone lan
    [DumaOS] applying qos for zone wan
    [DumaOS] Resync R-App store cloud
    [DumaOS] NSS delete root for interface 'br0'
    [DumaOS] NSS delete root for interface 'brwan'
    [DumaOS] config write 'com.netdumasoftware.hybridvpn.settings'
    [DumaOS] Backing up settings to config partition.
    [DumaOS] Ubus object 'com.netdumasoftware.dpiclass' now bound
    [DumaOS] Dependency loaded 'com.netdumasoftware.devicemanager'
    [DumaOS] All dependencies loaded, starting
    [DumaOS] Cloudsync DPI result 'false','All mirrors are down'
    [DumaOS] App 'com.netdumasoftware.desktop' initialised & starting.
    [DumaOS] Cloudsync Themes result 'false','All mirrors are down'
    [DumaOS] config write 'com.netdumasoftware.desktop.database'
    [DumaOS] config write 'com.netdumasoftware.devicemanager.dpisettings'
    [DumaOS] config write 'com.netdumasoftware.devicemanager.database'
    [DumaOS] Dependency loaded 'com.netdumasoftware.autoadmin'
    [DumaOS] Ubus object 'com.netdumasoftware.networkmonitor' added, attempting to bind pending
    [DumaOS] App 'com.netdumasoftware.neighsync' initialised & starting.
    [DumaOS] App 'com.netdumasoftware.geofilter' initialised & starting.
    [DumaOS] Waiting for 'com.netdumasoftware.autoadmin' to run before starting
    [DumaOS] Waiting for 'com.netdumasoftware.devicemanager' to run before starting
    [DumaOS] pending subscription for package 'com.netdumasoftware.dpiclass'
    [DumaOS] pending subscription for package 'com.netdumasoftware.devicemanager'
    [DumaOS] App 'com.netdumasoftware.hybridvpn' initialised & starting.
    [DumaOS] App 'com.netdumasoftware.devicemanager' initialised & starting.
    [DumaOS] subscribe to 'com.netdumasoftware.neighwatch' from 'com.netdumasoftware.devicemanager'
    [DumaOS] App 'com.netdumasoftware.qos' initialised & starting.
    [DumaOS] App 'com.netdumasoftware.networkmonitor' initialised & starting.
    [DumaOS] Ubus object 'com.netdumasoftware.procmanager' added, attempting to bind pending
    [DumaOS] Ubus object 'com.netdumasoftware.neighwatch' added, attempting to bind pending
    [DumaOS] Ubus object 'com.netdumasoftware.systeminfo' added, attempting to bind pending
    [DumaOS] App 'com.netdumasoftware.procmanager' initialised & starting.
    [DumaOS] Non-existent publish method 'licence_permitted'
    [DumaOS] App 'com.netdumasoftware.neighwatch' initialised & starting.
    [DumaOS] DHCP new lease allocated.
    [DumaOS] DHCP new event.
    [DumaOS] subscribe to 'com.netdumasoftware.arpwatch' from 'com.netdumasoftware.neighwatch'
    [DumaOS] App 'com.netdumasoftware.systeminfo' initialised & starting.
    [DumaOS] Starting process manager
    [Initialized, firmware version: V2.3.2.114]
    • Netduma-Liam's avatar
      Netduma-Liam
      NetDuma Partner
      If you go to System information on the XR500, is it showing a WAN IP from the router?
      If not, are you able to see any information about the XR500 on the admin interface for your modem?
