RNGeus000's avatar
RNGeus000
Port Forwarding
im trying to make a unturned server andi opened the port 27015 and when i laugh the server no one can join and when i check it it says its closed timed out but the server open to that port but no one can join or anything.  ive done everything so im about to change to a differnt routher and see if it works
  • schumaku's avatar
    schumaku
    Any other NAT device (ISP modem/router) in front of the R7000N?
    Your ISP does assign a public IP address to the router WAN/Internet interface some Carrier-Grade NAT (CGN) as per RFC6598 or a private RFC1918 address?
    Correct protocol forwarded - UDP or TCP?
    Service up and running, no host based firewall prohibiting access?
    • RNGeus000's avatar
      RNGeus000
      I have only the one router and I have to use both protocols and I’ve did it both ways to see and no luck. And I turned off my firewall and didn’t work so I added a rule to me firewall and no luck so I don’t know. I just need to fix this Bc now when I check port 80 it’s closed too.
      • schumaku's avatar
        schumaku
        Where to is the WAN/Internet port connected?
        What is the first number of the WAN/Internet interface assigned IPv4 address (Advanced tab - Internet Port - IP Address)?
