SpicyGeek's avatar
SpicyGeek
Follower
Aug 02, 2025
Power Interruption and 2.4GHz stops working
Every time I have a power interruption, the 2.4GHz on my XR1000v2 quits working.  The 5GHz works fine though.  The last time this happened, I talked with technical support on the phone and the only way we got it working again was doing a factory reset.  I am tired of having to do a factory reset every time a power interruption occurs.  It is time consuming getting everything reset and all my devices reconnected.
Is there another way to get the 2.4GHz working again?
Thank you.
P.S. I have requested they replace the device.
  • CrimpOn's avatar
    CrimpOn
    Just curious. Does the same thing happen when the router is deliberately rebooted using the web interface?
  • Make all your changes and then reboot the router from the interface, this acts as a hard save and so should then in theory prevent it happening when power is lost
