petterpan's avatar
petterpan
Problem connecting to wifi with the newest firmware V1.0.1.38 on xr700
Having problem connecting my Oneplus 8 Pro to the wifi after updating the xr700 to firmware version 1.0.1.38
Its trying to obtain ip adress but is failing.
Only way to connect is to manually input dns server.
Tried downgrading the xr700 firmware and then it is working again.
  • Also my xiamoi security cam is not able to connect to wifi anymore
    • Netduma-Liam's avatar
      Netduma-Liam
      NetDuma Partner
      Did you perform a factory reset after the upgrade? This is often required as it clears anything low-level left after the old version
      • petterpan's avatar
        petterpan
        Yes, I did a factory reset, also I found out that the issue is not reletadet to only wifi becouse my wired lg smart tv is having the same problem.
        I get the error message "DNS not found"
        But when i downgrade firmware its working.
        So in short   Oneplus 8 pro = not working (can maually input dns server and then its working)
                            xiamoi security cam = not working
                            Lg smart tv(wired) = not working
                            Win 10 computer = working
                            Arlo = working
        Have tried factory reset, hard reset, restart of both fiber media converter and xr700 router.
