jachcck
Apr 18, 2020Aspirant
R7800 router, no connection after reboot
No auto connection after firmware update to 1.0.2.68
Router r7800 cannot connect to internet automatically after reboot. I can only make it connect to unplug the lan cable and reconnent it.
How can i solve it?
How can i solve it?
what modem is it connected to? (model?)
- jachcckAspirantNo modem. Just directly plug the lan cable.
Pretty sure is the firmware problem. It was only happened when i updated the newest version.- plemansGuru - Experienced User
It might be the firmware. Anytime there's an issue after a firmware upgrade, a good first step is to factory reset and re-install the router.
If that doesn't fix it, you can try downgrading it.
The other thought was that ethernet connection is coming from somewhere. you haven't said a word about it. does your isp have an ONT, a router that serves the whole community, whats going on there? maybe the ISP or whatever's setup made a change to what it allows to connect or how it allows them to connect.
You might try Voxels 3rd party FW as well.
Good Luck.
How can i solve it?
