OlegP
Sep 05, 2019Apprentice
ReadySHARE not working with Windows 1903
So I've had 1903 upgrade install itself on all of my Win 10 machines at home and it has killed the ReadyShare utility on all of them.
It will not display a USB printer anymore when I launch the utility. I've reainstalled the latest 1.36 version several times without any success.
After digging around on the interwebs, I found someone mentioning that the ReadyShare application is not compatible with the latest 1903 build.
Is there a fix for this or is there a newer version in the works?
Thanks
- Netduma-FraserNetDuma PartnerSounds like there needs to be an update to ReadyShare, I will pass this on to Netgear.
- OlegPApprentice
Much obliged since we rely on the utility in order to use one of our USB-only laser printers.
- OlegPApprentice
Any news about the Windows print share utility or can someone from Netgear tell when it'll be available to be used on the latest Windows build? I'm surprised that it's taking so long since 1903 has been out out for a while and surely I'm not the only one that has encountered this issue by now.
Thanks
- Netduma-FraserNetDuma PartnerI haven't heard anything but I will chase this up for you.
I cant seem to get ReadySHARE to work anymore either... have we figured out a solution yet?
- Netduma-FraserNetDuma PartnerHi Sladner84, you have a different router so it would be best if you posted in the Nighthawk WiFi router section if you're having issues.
