droesw's avatar
droesw
Guide
Oct 24, 2019
Settings for lowest latency?
I have an xr500 and a docsis 3.1 modem my isp provided to me, and I play xbox one on ethernet. I know that it’s recommended to use QOS and the geo-filter to help with latency and overall gaming connection, but are there any additional settings to change from the factory default settings that could help lower latency?
  • FURRYe38's avatar
    What SPEED up and down do you pay for from your ISP?
    What is the mfr and model # of the ISP modem your using?
    I use 70/70 on my XR450. C7800 in modem only mode. 200/10 ISP service. Two game consoles online. sometimes at the same time.
    • droesw's avatar
      droesw
      Guide
      I pay for 200/10, but usually when I do speed tests without QoS enabled I get around 230/12.
      I'm not finding any mfr number, but the model number is Ubee E31U2V1. And like I said it's a docsis 3.1 modem, and my isp is spectrum.
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        Did you follow the guide to optimally set up the router? How are you getting on?
