GUNZZ72's avatar
GUNZZ72
Slow Ethernet speed xr1000
I got the nighthawk pro gaming xr1000 today and hardwired to my Xbox. I pay for 500mbps download and 20upload. The Xbox is showing I’m getting only 200 mbps and 20 upload. My old router I was around 400 download. Just seeing what could cause this.
    Make sure you upstream device is a modem only or a modem/router configured in bridge mode.
    When you add new pieces to your LAN, you need to power down all of the devices (pull the power cord) and then power them up sequentially so they can connect and work with each other.  Power up the modem first, wait for it to fully boot and stabilize, then the XR1000, wait for it to fully boot and stabilize.  Then power up the remaining devices.
      • Kitsap's avatar
        Kitsap
        Master
        What is the brand name and model number of the modem/gateway/ONT that is connected upstream of your XR1000?
        Have you installed the Netgear application on your phone and tested the throughput capacity from your internet connection to the router?  If yes, what were the results?  If no, it would give you another data point.
