Compoza_'s avatar
Compoza_
Luminary
Mar 09, 2021
Something is wrong with the Geo filter
https://imgur.com/a/CJeTmdg
It seems like the Geo Filter is broken now, take a look at the picture. Any ideas?
Regards
  • When that error appears, wait 1 minute and then refresh the page - it will have successfully flushed the cloud. What was the ping to that server?
  • It's likely the host is outside your zoom level, if you zoom out fully do you see the host? Did you enable filtering mode/change settings while you were already on the game?
    • Compoza_'s avatar
      Compoza_
      Luminary
      Yes, I did see the host, it was in south africa. I live in Sweden och have set the geo filter point where I exactly live in Sweden, Europe," you can see it in the uploaded picture" and the host was on the other side of the planet. I did enable it before starting my PS4 console.
      • Netduma-Liam's avatar
        Netduma-Liam
        NetDuma Partner
        What game are you playing where you're seeing this? Are you seeing it across all games?
