Compoza_
Mar 21, 2021Luminary
Traffic Prioritization
High Priority Traffic Detected is still active despite I have my ps4 pro totally shut down. This causes alot of problem when I have Anti-Bufferbloat set to "When High Priority Traffic Detected". This problem will only be solved through rebooting the router, but that shoudln't be the case. Any news for DumaOS 3.0 for the xr300? I only see new updates for other routers that already got the DumaOS 3.0 beta.
- Netduma-FraserNetDuma PartnerWe are aware of some issues with TP on the 300, are you using Classified Games or did you make a manual rule? We are working on it but I don't have an ETA at present
- Compoza_LuminaryI'm using Classified Games.
- Compoza_Luminarycould I use third party firmwares for my router?
- Netduma-LiamNetDuma Partner
Could you please try manually making a rule for your Playstation and see if the issue persists?
I'm afraid not, you'll only be able to use DumaOS firmwares.
