parasmrut
Feb 23, 2023Follower
Upnp doesn't work on ps5 - Netgear Nighthawk xr500
Please fix this.
I dont want use port forwarding I have destiny on pc and ps5 both it doesn't work.
Please have upnp working, my nat type shows as strict ... other game son ps5 like apex and warzone all have moderate nat type, why only destiny 2 can't use upnp properly?
- Netduma-LiamNetDuma Partner
Good advice above.
Are you using Geo-filter? If so, could you please disable filtering mode as a test and see if your NAT type in game goes to open?
uPnP works fine on the XR router.
For Sony consoles you'll never see NAT1. NAT 2 is always seen with a ISP Modem/Router configuration. To get NAT 1 you would have to connect the console directly to the ISP modem/ONT
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
