catan92
Oct 24, 2019Aspirant
Use 10Gb port for LAN Nighthawk
Is it possible to use the 10Gb LAN SFP port as LAN w/o internet?
Check the usual manual for official uses for that port.
- Netduma-FraserNetDuma PartnerAre you wanting to use the router as a LAN switch or just have that specific port without internet and just for LAN?
- catan92AspirantJust that specific port for LAN
- JoveticAspirant
Yes you can, I have my HP Microserver hooked up using the 10GB port. Not really of much use as its limited by the rest of my network, but I had a card laying around so thought why not :P
