Murllin's avatar
Murllin
Using the Nighthawk XR 500 in AP mode
I recently purchase the nighthawk XR500 router. It seems to have alot of great network performance enhancing features. However, my ISP provides a modem/router combo that is set up to provide wifi to one house and then the XR500 provides wifi for another house. I assume Im supposed to set up the XR500 as an Access point then since it is second down the line and (from what Ive read) will prevent any DNS conflicts. My concern then, is using the XR500 as an AP going to cripple its performance as a gaming hub. Should i be using a less expensive alternative as an AP. Since the ISP provided router is still handling the network addressing and all.
  • FURRYe38's avatar
    When in AP mode, ALL router features are disabled on the XR500. Only wireless is left running.
    You can do the following:
    Modem Combo Units:
    Couple of options,
    1. Configure the modem for transparent bridge mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
    2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the NG router gets from the modem.
    • Netduma-Fraser's avatar
      Netduma-Fraser
      NetDuma Partner
      Great advise above! What do you mean by two houses? As I would highly suggest you do not have anything connected to the ISP hub otherwise the QoS on the router will not be able to control all devices.
      • Murllin's avatar
        Murllin
        There are 2 houses because my set up is a bit unconventional. The ISP in my area does not service my home. They do service my neighbors home 400 feet in front of me. So Ive made an arrangment with my neighbor to set up and pay for internet service at their house, providing them with free wifi. Then I have an ubiquiti nanobeam installed on our roofs that send the signal to my own home as well. So theres the ISP provided router in their home that is connected via nanobeam to my home and into the XR500.
    • Murllin's avatar
      Murllin
      Thanks, those are good suggestions. I thought about bridging the connection. However in doing so that would disable the wifi access at the first house. Unfortunatly I have to provide wifi coverage for both homes. Would it be possible to instead, install a modem without router functions at the first home and then attach a switch to the modem. Would I be able to put a seperate wifi router in home #1 and then use my XR500 as a wifi router in home #2?
      • FURRYe38's avatar
        No that is not possible.
        Your best solution if you need to supply internet and wifi access with the home #1 would be to use the ISP modem and wifi there, then use its DMZ for the XR router at home #2. You can leave the wifi enabled at the ISP modem in your case since the distance between the modem and XR router are far.
        Ok now that you posted distance. If your getting wifi via wifi beam, then I believe this would work with the XR in router mode. However having all this wifi devices and beam in the middle, you may see odd or bad gaming performances in this kind of configuration. Having different methods to get from one point to another while data traverses these could pose a problem.
