Funstuff's avatar
Funstuff
Apprentice
Apr 14, 2021
Using XR500 and unable to connect to shared PC with file explorer
Hello,
I have been working on this for awhile now, I am using the XR500 DumaOS 3.0 beta .120 build but I doubt that is the issue.
I am guessing it is a DNS issue somewhere but after searching the DNS issues people are having with Netgear/Duma routers I think I am more confused :)
I can ping remote PC by name and IP
nslookup returns:
C:\WINDOWS\system32>nslookup jt
Server: UnKnown
Address: xxxxxxxxxxxxxxx
*** No internal type for both IPv4 and IPv6 Addresses (A+AAAA) records available for jt
I am able to remote login to the remote PC, I got FTP working with port forwarding on, hhowever when I try to use file explorer to open any shared directory or drive on the remote PC I get:
[img]https://i.imgur.com/LbiTBnE.png[/img]
I have not tried making my own hosts file, that seems a bit ancient now days and have not messed with doing a DNS server. Although after reading issues others have that might be the case.
Any help appreciated, thanks,
John
  • Hey John,
    Thanks for all the information! Could you give us a better idea of your environment and where your PC and the remote PC sit in it?
    • Funstuff's avatar
      Funstuff
      Apprentice
      Netduma-Liam  Sorry, providing more info.
      These are two home PCs. Both are running Operating System: Microsoft Windows 10 Professional (x64) Build 19042.928 (20H2).
      Everything is hardwired with cat8 as far as the devices concerned.
      The PCs are about 6 ft apart and each are connected to the router with 10ft of cable to the XR500 which is about 2-3 feet from each PC.
      The modem is right next to the XR500
      Router modifications:
      Changed router IP
      Added both PCs to the address reservation table due to suggestion from beta test and the device manager on the router.
      Windows defender firewall
      Bitdefender
      No VPN
      Modem: MB8600
      Router XR500 is running DumaOS V2.3.2.120
      PCs: Asus G11CD
               Digital Storm semi-self picked build
      68-72 degrees, no precipitation, just kidding
      Not sure what all you are looking for, just let me know if you need more.
      John
    • Funstuff's avatar
      Funstuff
      Apprentice
      Netduma-Liam  Oh my, I am soooo sorryy, I responded to this a while back but it must not have gotten sent or something.  Anyway I'll retype.
      Ok they are 2 machines running: Operating System: Microsoft Windows 10 Professional (x64) Build 19042.928 (20H2)
      Asus G11CD
      Digital Storm build
      Modem: Motorola MB8600
      Router XR500 build v2.3.2.120 beta
      Everything is hardwired, cat8
      The PCs are approximately 6 feet apart  and the modem and router are on a table in between about 2-3 feet from either PC.
      Changes to router are:
      IP of router
      Both PCs are set in the IP reservation table due to previous test for device manager issues on the router
      DNS servers set to cloudflare and Cisco
      QOS disabled per suggestion for the e-mail logs crap I have been messing with.
      IPV6 enabled with auto detect
      I think that is it, holler if you need more.
      Thanks,
      John
    • Funstuff's avatar
      Funstuff
      Apprentice
      Netduma-Liam  My reponses are not getting posted, trying a 3rd time. I am sooooo sorry I thought I replied to this several days ago.
      PCs:
      G11CD
      Digital Storm build
      Both running Operating System: Microsoft Windows 10 Professional (x64) Build 19042.928 (20H2)
      Router: XR500 v2.3.2.120 beta
      Cables: cat8
      The 2 PCs are about 6 feet apart and the modem and router are on a table about 2-3 feet away from the PCs.  Everything is hardwired pertaining to this scenario.  There are wireless things but not involved.
      Router changes
      IP of router
      both PCs are in the IP reservation table for another test of the router device manager
      QOS disabled per suggestion from messing with the router e-mailing logs I have been messing with
      IPV6 enable auto detect
      DNS set to Cloudflare and Cisco
      Thanks,
      John
  • Netduma-Liam  This is my 4th reply to this and it is getting very irritating retyping everything. At first I thought it was my issue but I don't think so. Trying again...
    The 2 PCs are:
    Asus G11CD
    Digital Storm build
    Both using Operating System: Microsoft Windows 10 Professional (x64) Build 19042.928 (20H2)
    The 2 PCs are both hardwired to the XR500 router with cat8. They are approximately 6 feet apart and 2-3 feet each from the router and modem which are in a table in bewteen.
    There are some wireless devices but not involved in this scenario.
    Router changes:
    IP of router
    PCs IP addresses are in the reservation table per a test for the device manager
    IPV6 enabled, auto detect
    DNS severs are Cloudflare and Cisco
    Sorry for the delay, I thought my posts were being posted,
    John
    • Netduma-Liam's avatar
      Netduma-Liam
      NetDuma Partner
      Sorry to hear that your posts were not being made!
      Could you confirm if you have access to the shared driver with both PCs connected directly to the modem? This means we'll know if this is something we can adjust in DumaOS/Netgear settings to make this work!
      • Funstuff's avatar
        Funstuff
        Apprentice
        Netduma-Liam  Unfortunately my modem only has one rj-45, so do not think it is possible.
        I do have an old Netgear MR314 router I could hook up.  Would that be sufficient to test your theory?
