PachaTC's avatar
PachaTC
Guide
Dec 23, 2021
Virgin Media TV home screen not loading thumbnails - Nighthawk XR1000
Hi All
I hope someone knowledgable can help!?
Yesterday i took the plunge and installed a Nighthawk XR1000, everything seems to have connected to it fine and I am now getting to grips with the DumaOS.
The one issue i now have is with the Virgin Media home screen, the thumbnails have stopped loading/displaying images, instead replaced by the descriptive text, same with the app icons like Netflix. I imagine i cant be the only person this has affected with a Nighthawk/VM setup, please can anyone share what i need to change in the DumaOS so that the VM allows the images to load?
I have done some searching on this and only found answers like 'the router must be using VM DNS' and 'the router must be set to DHCP / Automatic WAN IP' but ill be honest this doesnt mean much to me and i couldnt see anything obvious in the DumaOS that linked to it.
Any help would be greatly appreciated!! Netduma-Fraser  hope you or another expert can help?!
Thanks
  • It will be using those settings automatically so not need to worry about that. Toggle IGMP Proxying in WAN Settings, then see if it works please
  • plemans's avatar
    How are you actually connected?
    What modem/gateway is the XR1000 connected to?
    And is the "home screen" through one of virgin's streamers/media boxes?
    • PachaTC's avatar
      PachaTC
      Guide
      Hi!
      The Virgin Superhub 3 is in modem mode, XR1000 connected to that via ethernet, Virgin Media Tivo box connected to XR1000 by ethernet also.
      The Virgin box is happily connected and i can watch on demand for example, however the thumbnails dont load the images, same for the app icons.
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
