lverberkt's avatar
lverberkt
WiFi problems with Netgear nighthawk R7800
Hello, I'm having issues with my wireless connections, 2.4 and 5 ghz. The WiFi is enabled according to the second light of the right is on. When I login with routerlogin.net I see wireless warning off. When I press on wireless i'm redirected to Advanced Wireless Settings where I see that Enable Wireless Router Radio is checked. I've set back the factory settings a few times now without any success. I've tried several firmware versions (.62 , .63 and now on .58), all with the same issues. The led light of 2.4 and 5 is off.
