Link8900's avatar
Mar 31, 2019
Xbox One X upload issues
Hello,
I have posted on the Xbox forums about this but I still cannot resolve this issue and wondering if anyone has advice.
All of a sudden over the past few days my upload speed JUST on my Xbox will not go over 1.5-2.0MBPS. I usually get anywhere between 15-20BMPS upload on the Xbox. I have reset the Xbox, reset the  XR500 router, reset the modem, cleared the persistent storage etc etc. My PC/Iphone/PS4 are getting perfectly fine upload speeds. This is just the Xbox.
MY ISP is COX 1gb 1000 down 35 up with unlimited data
IPV4 & IPV6 are enabled and my NAT is OPEN. I do not have geo filtering enabled.
WIRED connection but I get the same result if I go wireless and ive tried different CAT 7-8 cables.
I don't think the issue is with the XR500 being that my PS4 and other systems upload are just fine but I am at a loss on what to do.
  • FURRYe38's avatar
    Is the xbox wire connected?
    If other devices are are working well and it's just the xbox, then possibly the xbox is the problem.
    Besure to disable Instant ON on the xbox. This is known to cause problems.
    • Link8900's avatar
      Link8900
      Tutor
      Thank you for the reply.
      I use the ARIS Sb8200. I've done some research and it seems like multiple people are having the same issue just with Xbox. I even directly connected the xbox to the modem with the same poor upload results. I guess I will have to see what Xbox has to say.
      • FURRYe38's avatar
        Ya, if you directly connected it to the mode and seeing same issue, thats a console issue.
        Good luck.
