chrismcglock's avatar
chrismcglock
XR 300
XR300 1.0.3.56_10.3.41
Hi I have been experiencing a lot more lag then I use to get recently so I checked if the router needs to be updated but it says its up to date. I then checked duma os dashboard and I am no longer able to see how many devices are logged on and how much speed to adjust for each. The whole side bar is blank. Is there something wrong with my Duma os?
  • Can you attach a screenshot of the entire page/browser of what you're seeing please?
    • chrismcglock's avatar
      chrismcglock
      Yes thank you! When I login to duma os it says script error 5-8x before letting me in then shows this.
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        Can you attach it instead otherwise we have to wait for the picture to be moderated. You may need to do a factory reset then in that case to resolve the error and the other issue
      chrismcglock
      any suggestions on how to attach a screenshot from a mac? its saying its to big?
      • FURRYe38's avatar
        This is what I use for OSX:
        Take screenshot of a specific region
        Press Command + Shift + 4 and your cursor will turn from arrow to crosshair. Move and drag the crosshair cursor on the region you want to take screenshot of and it will be saved on your desktop.
