Sureshot08
Nov 24, 2022Tutor
XR1000 cant connect to geofilter and pingmap
I all of a sudden am not able to use or connect to the duma os features geofitler or heat ping map. I have the latest version XR1000 1.0.0.64_1.0.49 have cleared my cache and cant find anyway to get the web browser to work. I am currently using the edge browser
That's a specialist thing related to your gaming router.
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Nighthawk Pro Gaming Routers - NETGEAR Communities
Gaming routers have their own DumaOS operating system that is nothing like the one on Netgear's standard routers.
You might like to search there for messages related to your problem.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads. - FURRYe38Guru - Experienced User
Be sure to clear out all browser caches before entering the routers web page.
Might try FireFox as well...
- Thank you, I'll give Firefox a shot
I am unable to access both the geofilter and ping heatmap. every other aspect of the browser and UI work fine but those two either try and load forever or produce the error message rapp wont load wait a minute. I am on version XR1000 1.0.0.64_1.0.49
Heres what ive tried from some other posts:
Setting the rapp retry limit to 5
Downgrading firmware to a few different versions
Using both Microsoft Edge and Chrome
Deleting cache and cookies
Hard resetting router
