BIGRIFF's avatar
BIGRIFF
XR1000 dropping out every couple of hours
Im getting the same issue and i dont know what to do to fix it.
I have reserved all my devices from .2 to .49 and set the DHCP range from .50 to .99 and yet im still experiencing a dropout which disconnects me from momentarily, cutting my stream to twitch.
Every time it drops out, I get these errors when it happens.
"Jan 30 20:22:43 XR1000 user.emerg httpd: ****handle_get(411)  66
Jan 30 20:22:43 XR1000 user.emerg httpd: ****handle_get(675)  66
Jan 30 20:22:43 XR1000 user.emerg httpd: ****handle_get(699)  66"
any idea what is causing this?
  • Are you only receiving the issue on the streaming device or other devices as well? What are the speeds you pay for/receive?
    • BIGRIFF's avatar
      BIGRIFF
      Unsure, no way to really tell, it literally drops for such a small amount of time, just enough to make my OBS disconnect and then reconnects on the first try afterward.
      We pay for 1000down and 100up and recieve these speeds reliably.
      I have just updated the router bios to the latest 1.0.2.86_2.1.40 and am going to factory reset it and hopefully upload a backup file to restore all the settings as right now after the update, DumaOS keeps crashing whenever I do a speed test.
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        If you have updated you should not restore a backup file from a previous firmware version, start completely fresh. Skip the speed test part, it's not always accurate, should then allow you to get past it.
  • FURRYe38's avatar
    FYI, ANY IP address reservations need to be with in the DHCP IP address range. Not outside of it. Static IP addresses are used OUTSIDE of the DHCP IP Address range. IP address reservations are WITHIN the range.
    I have both XR500 and XR1000 routers and run a .100 to .150 default IP address range. Any and ALL IP address reservations are with in the range. I do have a few devices that use static IP addresses that are outside of my DHCP range. Never have any drop outs.
  • FURRYe38's avatar
    Updated FW on my XR1000v1 yesterday to v1.0.2.86. Factory reset and setup from scratch using .100 to .150 default IP address pool range.
    Have a few static IP addressed devices out side of this pool range. Couple of other devices dymanic IP addressed from with in this pool range.
    System as been online and solid since...No drops seen.
    • FURRYe38's avatar
      6 Plus up days on my XR1000v1:
      Firmware Version V1.0.2.86_2.1.40
      Basic Information
                CPU Load
      CPU1: 15.32% CPU2: 15.28% CPU3: 0.09%
                Memory Usage (Used/Total)
      429MB/497MB
                Flash Usage (Used/Total)
      125.35MB/256.00MB
                Network Session (Active/Total)
      743/65535
                System Uptime
      6 days 16:14:37
