sdog1010
Jan 24, 2023Guide
XR1000 dumaOS not loaded yet
Hi I have a XR1000 Router and when i try to log in with the 192.xxx.x.x it comes up with dumaOS not loaded yet. Can someone help?
Firmware Version: V1.0.0.64_1.0.49
- sdog1010Guide
add: the router is connected to a netgear CM1000v2 modem
- Netduma-LiamNetDuma Partner
Can you disconnect the power cable from the XR1000 for ten minutes, then reconnect it again and after a few minutes see if you're able to access the interface?
- sdog1010Guide
explain to me like im a two year old what the R2 is đ
Be sure to clear out all browser caches before entering the XR1000s web page.
Try a different browser. I use MS Edge here.
