Christiaan11's avatar
Christiaan11
Apprentice
Sep 26, 2022
XR1000 error
Hi all,
Since a while I have the Nighthawk XR1000. Overall I'm disappointed of what it can do but that's another discussion.
since a while I now have the error below. I thought it was just an web interface error but I also noticed that the geo filter its;t working anymore. Not sure it's related with this issue?
TypeError: undefined is not an object (evaluating 'i.generateKey')
Thanks for the support.
  • Okay so Safari forces HTTPS which is why you will have been getting those errors, the interface works best through HTTP.
    Try this for the Geo-Filter:
    Quit game back to the console dashboard
    Remove device from the Geo-Filter
    Resync from the Geo-Filter Map menu
    Re-add the device to the Geo-Filter with the manual option
    Set up the Geo-Filter how you like
    Wait 2 minutes
    Boot up game
    Then see if it works better.
  • FURRYe38's avatar
    What browser are you using? Happens in different browsers?
    • Christiaan11's avatar
      Christiaan11
      Apprentice
      Firmware is the following: XR1000 1.0.0.64_1.0.49
      The modem it's connected to is a Connectbox Giga / Eurodocsis 3.1 modem from Ziggo in Netherlands.
      I have to say at the start I didn't have this issue at all. It started to occur later.
      Thanks!
  • What pages is this error appearing on specifically? What web browser/device are you using to access? Are you using Armor? Could you expand on what you mean by the Geo-Filter isn't working - is it showing an error?
      Christiaan11
      Apprentice
      Thanks for the reply.
      • Error is showing on each of the DUMA UI pages in the web interface. The regular settings I can access without an issue.
      • When I get the error I click OK and can interact with the interface.
      • I'm using Safari browser on Mac.
      • Geo filter isn't working as I used to see it connect to servers in the Duma UA. Now while gaming it stays blanc. I removed the profile and added my PS5 again but it is still not working.
      • I'm not using Armor. I do have the license, but when I tried to turn it on using the app it gives me a time out.
        Christiaan11
        Apprentice
        Ok, switching to Chrome solved the TypeError issue. Maybe it's a cache thing in Safari. Will have a look!
        GeoFilter however is still not working. Will looking for a game no servers show up while it is connecting to one on my PS5. I did remove and add the profile again in Chrome.
