Xr1000FTW's avatar
Xr1000FTW
xr1000 latest patch ethernet drops
since the newest patch couple days ago ive experienced 2 ethernet drops wifi still works
  • It was just a security update so nothing else has changed, may be worth a factory reset depending on the last time you did one - I generally recommend doing it after every update
    • Xr1000FTW's avatar
      Xr1000FTW
      the patch before this 1 been working fine until i did this 1 current fix is i switched ethernet port but never had this issue before
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        In LAN Settings, set the DHCP range to start at .50, then assign reserved IP addresses to devices between .2 & .49 so they're out of the DHCP range, apply, reboot from the interface, wait 4 minutes and see if that stops the disconnects.
