Geiokami's avatar
Geiokami
XR1000 Port forwarding ui glitch
I got a Nighthawk XR1000 from my isp, when trying to forward ports it only sometimes actually goes through but when i try to edit or delete one the ui will glitch and edit/delete the entry above it. (ex. list is server 1, server 2, and server 3. i want to edit server 2 so i select it and hit edit but it opens server 1 instead.) i can not remove all the ports because selecting the top one on the list (to edit the last one) causes the router to kick me out for a few minutes giving me a connection error. So its stuck with 1 entry always being there.
So 2 issues, the Ports not actually opening and the weird ui glitch.
  • FURRYe38's avatar
    Whos your ISP?
    • Geiokami's avatar
      Geiokami
      What Firmware version is currently loaded? 1.0.54.10_5.0.11
      Whos your ISP?  Grande communications
      What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? Arris Touchstone CM8200A
      As above, also what device and web browser are you using to make the changes? tried on 4 different computers and a phone.
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        Could you disable Armor from the app if you have it enabled and then try again please?
