longr5310's avatar
longr5310
XR1000 Pro Gaming Router DUMAOS WIFI 6 Router
I cannot understand why Madden is not listed in the ping heat map drop down menu?! I'm pretty much stuck with the games that load in the ping heat map drop down box... most games that i don't play. The ping heat map is the magic behind most of the gaming with this router and if your game isnt listed to select the experience is average at best. I can only select Madden in the geo filter profiles and thats it and not in the ping heat map or any other portion of the router where you would select what game your playing.
  • Ping Heatmap just pings servers, it doesn't do anything other than that, it wasn't always a feature so you can still benefit by using the Geo-Filter and putting the location over your region to still get a great ping. I can make a request for the team to get it added to Heatmap.
    • longr5310's avatar
      longr5310
      Ok do I need to do a factory reset to obtain the feature you are referencing?
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        What feature exactly? Ping Heatmap and the Geo-Filter you already have access to as you mentioned
