Biggy5970's avatar
Biggy5970
Xr1000v2 geo filter ps5
I setup geofilter on ps5 with ping assist off and set it to USA cause there’s no games in Australia and it took 20 minutes to find a game and then it worked fine but tried today and just would find game waited and hour and nothing
  • The purpose of the router isn't to get you servers that far away from you, as your ping will be high there is no guarantee you'll get those games. If you're playing CoD there are servers in Aus.
    • Biggy5970's avatar
      Biggy5970
      Yeah understand that but there barely any warzone games and if there is it’s not a full lobby and was working no problem also nothing shows up on geo filter the server and people will pop up for a second then instantly go away
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        Try this:
        Quit the application/game/client completely
        Remove device from the Geo-Filter
        Resync from the Geo-Filter Map menu
        Re-add the device to the Geo-Filter
        Set up the Geo-Filter how you like
        Wait 2 minutes
        Boot up application/game/client
        Then see if it works better.
