DonnyMacT's avatar
DonnyMacT
Initiate
Sep 09, 2024
Xr1000v2 promoted straight to admin account settings
I just done a factory reset on my xr1000v2 Pro Gaming Router and I get promoted straight to admin account settings without me signing in to the router with the default account credentials? Any help would be highly appreciated thanks in advance
  • FURRYe38's avatar
    How was the router setup after you reset it and setup from scratch?
    Did you walk thru the setup wizard with a wired PC and web browser or use the Nighthawk app to set it up?
    During most setups, you should encounter a process where it will ask you to input a new admin PW during the setup then get into the home page from there. Next log in should ask you for this new PW.
  • If you hadn't changed the default credentials during the wizard when you initially setup then your browser has probably saved them so you can sign in quickly.
