agqasem
Jan 23, 2021Aspirant
XR300 — Nighthawk Pro Gaming Router disconnects alot
hi
my router keeps disconnecting throughtout the day for like 30 second every hour or so. i have tried factory resetting ( it made it worse imo). i have updated to the latest firmware and I feel like it only makes it worse.
would really like some help
- Netduma-LiamNetDuma Partner
Sorry to hear you're having troubles!
Are both wired and wireless devices losing connection?
Are you able to access the XR300s interface when these drops occur?
Does the connection come back up on it's own? If not, what do you do to reconnect?
- agqasemAspirant
both wired and wireless disconnect
I can access the interface when it happens
the connect comes back on its own after 1 min or so
- Netduma-FraserNetDuma PartnerWhat is your exact physical setup? What is the XR connected to and what is the model of that modem/router?
