hotpeppershrmp
Jul 03, 2022Aspirant
XR300 - Steam Problem
I'm playing Street Fighter 5 through Steam.
No access points appear on the Recent Geofilter screen.
It doesn't seem to be working properly at the moment.
I set my PC to the Playstaion, and I have both strict mode and automatic ping host, Ping Assistant, and Fast Search enabled.
- When you get that message just wait 1 minute and then refresh the page. It's important that when you do the steps above that the game has been completely shutdown as well as steam, even from the System Tray. If it's still not working please provide a screenshot of the Geo-Filter page.
- Netduma-FraserNetDuma PartnerDisable fast search, you won't get good games with that, do this:
Quit the application/game/client completely, steam included, even from the system tray
Remove device from the Geo-Filter
Give PC PlayStation Device Type in the Device Manager
Resync from the Geo-Filter Map menu
Re-add the device to the Geo-Filter with the manual option
Set up the Geo-Filter how you like
Wait 2 minutes
Boot up application/game/client
Then see if it works.- hotpeppershrmpAspirant
Nothing still appears on the ping map.
Does resync a map mean a flush cloud?
When you use the flush cloud, you get a message that it takes too long, and nothing changes.
- Netduma-LiamNetDuma Partner
Yes, that's fine it should still have flushed.
When adding the PC to geo-filter, did you select "Choose manually" instead of picking a specific service?
If not, do that and report back.
If that hasn't worked, after flushing the cloud, can you go to System Information and check if there's any entries in the logs that pertain to the cloud flush?
