bebo131
Mar 14, 2021Aspirant
XR300 Disconnects every 2 hours
My router XR300 keeps disconnecting/dropping me from any game that needs a constant connection like Call of Duty Modern warfare or Warzone every 2 hours consistently. I don't get dropped from every other application that require a internet connection loses it's ability to connect to the internet. This includes discord, web pages, streaming show and anything else not in the game. Has anyone come accross a fix that is actually a viable option. I hate to think that I bought a router that was this expensive and netgear can't even come up with a firmware update solution. everything in my computer is updated and working 100%
- Netduma-FraserNetDuma PartnerIt's weird it is just the game, are you using the Geo-Filter? If so if you disable that do you have a connection consistently?
- bebo131Aspirant
for some reason is only with warzone/ modern warfare. Everytime this happens my internet still works and others stuff keeps running just fine. This is the second same router that i get and the problem is the router. If i plug the ethernet directly to the PC from the Modem i dont have any problems i can play for many hours there must be a settings that i need to fix but i dont know what it is. My pc have everything updated plus mu ISP gave me a new modem additional to that i did some troubleshootings here on my pc and ebverything is ok. any solution for this problem
- Netduma-FraserNetDuma PartnerCan you disable the Geo-Filter please and see whether the issue continues?
- Gamer252Aspirant
I also own the xr300 and I also have same issues. When playing a game like Warzone or halo it just disconnect mid game. Very frustrating. I was hoping they would have DumaOS 3.0 available for the xr300 by now but sadly it's still not.
I have my pc connected with an ethernet connection. Turning geofilter off makes no difference.
- Netduma-LiamNetDuma Partner
Gamer252 Is it just the game that's disconnecting or is the entire network losing connectivity?
What firmware version are you currently running.
- Gamer252Aspirant
The game just disconnects but the internet (web browsing etc) works fine. I don't know which firmware its running because I went back to my old router but I did do a firmware update not that long ago (less than 1 month) so it's probably the current version.
It would be nice if you guys can allow the Duma 3.0 beta for xr300 routers. This way we can test to see if it's a hardware or software issue.
