Jordoncue's avatar
Apr 26, 2021
Xr300 drops my callof duty connection about every hour
It seems like every hour my connection drops and I get the disconnected from blizzards servers. I have done just about everything I've seen, to include reseting router and reinstalling windows. My pc is the one losing connection. It's ip is 192.168.1.11, the crazy thing is my wife plays on the xbox ,192.168.0.4 and never gets disconnected.
18:28:13 is where I first connected, and 19:49:14 is where it disconnected me. 21:19:11 is where I played again for about 40 min but then quit.
[UPnP set event: Public_UPNP_C3] from source 192.168.1.11, Sunday, Apr 25,2021 21:19:11
[UPnP set event: Public_UPNP_C3] from source 192.168.1.11, Sunday, Apr 25,2021 19:49:14
[DHCP IP: (192.168.1.8)] to MAC address 74:29:AF:XX:XX:XX, Sunday, Apr 25,2021 19:49:03
[DHCP IP: (192.168.1.7)] to MAC address 48:A5:E7:XX:XX:XX, Sunday, Apr 25,2021 19:30:10
[DoS attack: FIN Scan] attack packets in last 20 sec from ip [23.207.XXX.XXX], Sunday, Apr 25,2021 18:45:56
[Admin login] from source 192.168.1.15, Sunday, Apr 25,2021 18:38:29
[UPnP set event: Public_UPNP_C3] from source 192.168.1.4, Sunday, Apr 25,2021 18:37:57
[UPnP set event: Public_UPNP_C3] from source 192.168.1.4, Sunday, Apr 25,2021 18:37:36
[UPnP set event: Public_UPNP_C3] from source 192.168.1.4, Sunday, Apr 25,2021 18:36:53
[UPnP set event: Public_UPNP_C3] from source 192.168.1.11, Sunday, Apr 25,2021 18:28:13
  • Sorry to hear that, thank you for the information!
    Could you please answer the below questions:
    Do you get the same connection issue when you're not playing CoD?
    Does your entire connection drop or is it just a disconnection from the Blizzard servers?
    Is your NAT type open in game?
    Are you using Geo-filter? If so, how do you have it configured? Are any 'blocked' icons appearing on the map while you're playing?
    What firmware version are you currently running on the XR300? It's always worth making sure you're up to date.
    • Jordoncue's avatar
      Jordoncue
      Guide
      So I'm not using Geo filter. My NAT is usually open. Actually I don't think it has been moderate or strict in a long time. And yes it only happens with the blizzard servers. I can play other games such as Arma 3 all night long and never disconnect. I haven't seen any blocked icons, and the firmware is the latest.
      Note: I just purchased a xr1000 (like 10 minutes ago on the net gear site) I'm going to see if this solves my problems. However in the meantime I'm going to still try and solve my issues.
        Jordoncue
        Guide
        Here is my modem
        Arcadyan CM4652442 - eMTA MoCA 2.0
        I'm through mediacom. I also have a 1gig down and 100 up
