DevilsBlubber
May 29, 2023Guide
XR300 Nighthawk throttling speeds
Hello, the past few months I have been having issues with my Nighthawk xr300. Seemingly at random my wifi and ethernet connection speeds will drop from 350mbps to 70-100mbps. Last time I was able to resolve this issue by switching from the first ethernet port on the back of my router to the forth. I have tried searching the internet for answers and have tried a lot of the recommended solutions but none seem to work for my current situation. Any suggestions would be appreciated, thank you.
Things already tried:
- Rebooting router and ISP modem both through software and hard reset
- Updating firmware of Nighthawk xr300
- Factory reset of Nighthawk xr300
- Isolating router as issue (Direct connect to ISP modem gives normal speeds of 350mbps)
- Try all four ports on back of Nighthawk xr300
Firmware: 1.0.3.78_10.3.59
Note: Nighthawk XR300 wouldn't show up for associated products
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-routerBe sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
- Netduma-FraserNetDuma PartnerGenerally when it throttles it's due to your QoS settings, could you attach a screenshot of your QoS page please?
- Netduma-FraserNetDuma PartnerIt's still throttling with QoS completely disabled? What is the model of the modem/router the XR is connected to? Are ALL devices connected to the XR?
