jackson87's avatar
jackson87
XR500 - devices not connected to internet (in Singapore)
Hello guys,
Thought I come to you for help after going through different sources (I am in Singapore) including the forum post here, Netgear technical support, Singtel and Kaira (Distributor).
Background:
I am having some issues with getting games on my PS4 for FIFA 18 and sought to get the NightHawk XR 500 in a bid to optimise my packets and use the Geo-Filter on Netduma.
I am on Singtel Fiber Bundle - TV, Voice and Internet (1Gb). Previously used Asus RT and also recently changed to the AC Router. The connection is from fibre point to ONT (port 1) to Router. Voice jack is directly connected to the ONT.
Problem:
I connected everything as per normal to the new router and logged into the router to initialise it. The system boot up fine but could not detect the internet. After trying things out a few times, I chose the manual configuration so that I can bypass and get into the main router settings. Over there, I enabled Vlan tagging and the default is set to the internet, with Vlan ID 10 and priority 0. With this, I immediately got the light on the router to indicate internet connection and I also got the connected stated on the router's dashboard. However, I could not get internet to my devices.
I did some search and added in another Vlan tag, this time for the MioTv - Vlan ID 20, priority 4. So mio tv box works, but my internet situation is still the same. The router is communicating and connected with Singtel, but my devices beneath the router such as computer and mobile phones are unable to access the internet.
Remedies:
I have spoken to Netgear, Singtel and even Kaira (the most useless actually since they just directed me back to Netgear) and are unable to resolve this. Netgear's customer service while not having a physical presence in Singapore must be commendable if compared to Singtel and Kaira. They were really friendly, spent a good deal of time with me on the phone, did remote access to test things out but still could not get it to work.
They did ping websites using command prompt and there was no packet loss and came to the conclusion that they need to escalate this to their engineers and get back to me. The guy thinks there might be an issue with the Vlan working correctly as the router is receiving internet from the ISP (I have a WAN IP address), but for some reason is not distributing it to all the devices.
They dropped me another email this morning suggesting that I try internet Vlan ID 10 priority 4; and IPTV ID 20, priority 0.
I am just wondering if there's anyone who's using Netgear's XR 500 and on Singtel with MioTV and voice bundle. I cannot be the only person in Singapore who's using this? Any help is appreciated!
  • Hi Jackson, sorry to hear you're having trouble but happy that Netgear support was so helpful.
    What springs to mind is that your devices may have static IPs set on them individually left over from your last router, could you check a device to see if it's trying to connect automatically or via static IP?
    Regardless of that outcome, it doesn't sound like you've changed much on the XR500 itself but check DHCP, is it enabled?
    • jackson87's avatar
      jackson87
      HI Netduma-Fraser,
      Thank you for replying. I am not a network expert but from what I can see, they are not assigned static IP. There might be a couple with static, however not every one of my devices has that. I want to stress that the router is receiving a WAN IP and on the firmware is showing to have traffic going in and out between the router and the ISP / Internet.  I would think with that DHCP is enabled; well it is least showing up as DHCP connection type with the WAN IP.
      Case850 what do you mean known problem and it was supposedly resolved?
      J
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        So no devices connected have internet at all? How did Netgear conduct a remote session in that case? I would like to have a look as well.
