MBCruise's avatar
May 26, 2019
XR500 - MAC Wireless login to Routerlogin.net
Hi,
I cant log in to the routerlogin.net via my wireless macbook. It used to work, but now I cant login to the XR500 and the devices connected to the router. If I use an old Macbook with ethernet cable it works, but with the newer macbook with only wireless it dont. Any suggestions?
Br.
Mikael
    Whatever that means - not getting the browser-side login prompt for username & password, username or password not recognized, or the UI not loading, ...?
    Any kind of DNSCrypt on that wireless Macbook?
    What-if using the default gateway LAN IP (the router LAN IP address) in the browser?
    Using the Guest instead of the "normal" wireless?
  • schumaku's avatar
    schumaku
    • MBCruise's avatar
      MBCruise
      Tutor
      Hi, suddenly worked when switching to guest network :-), thx a lot
      • schumaku's avatar
        schumaku
        Hm, should work on the normal WiFi network, too.
