5m5me's avatar
5m5me
Follower
Aug 02, 2019
XR500 & Samsung Powerbot SR20M7070WS
Hello, I’ve changed my modem and router a little while ago and I’ve not been successful in connecting these devices to work (XR500 being the issue as I’ve done an isolation test) but I can work out how I can fix the connection issue. Has anyone been able to connect the two or similar device via a setting change somewhere?
  • FURRYe38's avatar
    Is Smart Connect enabled? Try disabling Smart Connect.
    • Netduma-Fraser's avatar
      Netduma-Fraser
      NetDuma Partner
      As above it is most likely to be smart connect, disable that and connect it manually to the 2.4GHz network. If that doesn't work try enabling guest WiFi and connecting it to that instead.
