G4Captain's avatar
Jun 27, 2020
XR500 5ghz Connection Problem
I have a brand new MSI GE66 with the Killer AX1650i. It connects to the 2.4ghz band no problem. It sees the 5ghz band, attempts to connect, but says it is unable to connect to that network. I have both the latest firmware available for the XR500, and the latest drivers available from Killer that were installed yesterday.
I have disabled smartconnect in DumaOS so I can pick which band it connects to. I have connected the GE66 to 5ghz band on a different router, so I don't think the problem is with the laptop.
Anyone have any suggestions on what to try? I've been emailng with Killer support, and I think they are about out of ideas to try.
Thanks.
  • When you try to connect to 5GHz does it connect with no internet or completely refuse to connect to the WiFi? Do you have any manual settings setup for the WiFi adapter?
    • G4Captain's avatar
      G4Captain
      Star
      It attempts to connect and then says it is unable to connect to that network. The only settings I changed were the names of the networks.
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        If you factory reset the router, leaving the WiFi names default but disabling Smart Connect does it allow you to connect then? Don't change anything else before you try.
