Mike40
Dec 08, 2024Luminary
XR500 Black Ops 6 no ping on PC
Just like the subject says. There are no pings when playing BO6 on PC. There isn't anything for BO6 in the Ping Heatmap either. This has been going on since the day the game launched over a month ago. I thought it would just resolve itself but it hasn't. This is the firmware I am using XR500 V2.3.2.134.
I have tried the following without success:
1. Restarted the router
2. Unplugged the router, waited a minute, plugged it back in
3. Unplugged the modem (CM2000) and router, waited a minute, plugged the modem back in, once the modem was up and running, I plugged the router back in.
4. I turned on/off Geo-Filter
5. I turned on/off QOS
I'm guessing some of what I did, I didn't need to do but thought I would try things before I came to the forums.
Is this normal or are you not supporting COD titles anymore?
- The beta is here: https://forum.netduma.com/topic/51611-new-xr500-beta-firmware-33535/
Try this:
Quit the application/game/client completely
Remove device from the Geo-Filter
Give PC PlayStation Device Type in the Device Manager
Resync from the Geo-Filter Map menu
Re-add the device to the Geo-Filter with the manual option
Set up the Geo-Filter how you like
Wait 2 minutes
Boot up application/game/client
Then see if it works.
Is the game working?
Probably something that may need to be added. If thats even possible.
Tried the NetDuma beta?
- Mike40Luminary
The game "works" but it doesn't work well since I can't use the Geo-Filter. I live by Chicago and the server is always trash. That is why I use the Geo-Filter so I can connect to either Ohio or Georgia. Playing MP is almost unplayable so I just play Zombies since having little glitches doesn't really mess with my game.
How do I get the beta? I would be willing to try it so that I can play MP again.- Netduma-FraserNetDuma PartnerThe beta is here: https://forum.netduma.com/topic/51611-new-xr500-beta-firmware-33535/
Try this:
Wait 2 minutes
