Chrch's avatar
Chrch
XR500 Blinking Red Internet LED
Router has been working fine. Get home and Internet LED is blinking red and lost router connection to Internet. Have tried cycling the modem, factory reset, nothing has worked. Internet works when wiring computer directly into modem, does not seem to be an outage or cable issue. Any suggestions?
  • what actual modem do you have?
    Try this.
    Power off both the modem and the router. disconnect everything from both (even coax from modem).
    Wait 2 minutes.
    connect coax back to the modem.
    power the modem on and wait 2 minutes.
    connect the modem to the router.
    power the router on and wait 2 minutes.
    Try it then.
  • plemans's avatar
    Try this.
    Wait 2 minutes.
    Try it then.
    • Chrch's avatar
      Chrch
      The modem is an Arris Surfboard SB6190. The extra step of disconnecting the coax as well seems to have done the trick, thank you!
    • Chrch's avatar
      Chrch
      Netduma-Fraser wrote:
      What firmware version are you on currently?
      I'm on V2.3.2.114 now. I was on 2.3.2.56 when the issue started. Do you recommend staying on the latest version?
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        Glad to hear it's all working now! Yes I would recommend staying on the latest version
