Xr500's avatar
Xr500
Apprentice
Sep 21, 2018
XR500 BUG
  • Firmware version : V2.3.2.32
  • QoS -> Traffic Prioritization -> Selector My Pc -> Advanced -> Port Start1  End65535  Protocol TCP&UDP  ->  DONE
  • Firmware Previous versions Qos Business as usual
  • I can't see the picture but is it an error message? If so we're aware and is fixed for the next firmware.
    • Xr500's avatar
      Xr500
      Apprentice
      Thank you for your timely response.
      Below is the details.
      RPC error 'ERROR_UNKNOWN': bad argument #1 to 'len' (string expected, got nil) -> stack traceback: ?: in function <?:73> [C]: in function 'len' ?: in function '?' ?: in function 'decode' ?: in function <?:50> (tail call): ? ?: in function <?:324> [C]: in function 'xpcall' ?: in function 'try' ?: in function <?:290> [C]: in function 'run' ?: in function <?:345> [C]: in function 'xpcall' ?: in function 'try' ?: in function <?:261> (tail call): ? /dumaos/api/cli.lua:48: in function </dumaos/api/cli.lua:30> [C]: in function 'xpcall' /dumaos/api/cli.lua:59: in main chunk [C]: ?
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        Yes thats the one we're aware of thanks, fixed in the next version
