David_allen09
May 15, 2020Aspirant
XR500 Disconnecting every day
Lately I have been getting disconnected from my router. This occurs after every DHCP lease event, which also shows several DOS attacks. But again, this only happens during the DHCP lease event. A thought occured to me that maybe I have too many devices? I can tell you that I am extremely tired of factory resetting this router. Below is a log from this morning when it happened.
Im a fairly tech savvy guy, but I do not know routers yet. Any help would be great, I would rather not have to buy another expensive router.
[DumaOS] DHCP lease change., Friday, May 15, 2020 00:57:08
[DumaOS] DHCP new event., Friday, May 15, 2020 00:57:08
[DHCP IP: 192.168.1.6] to MAC address 9a:32:2c:f2:2e:8c, Friday, May 15, 2020 00:57:08
[Internet connected] IP address: 47.188.197.221, Friday, May 15, 2020 00:56:19
[DumaOS] DHCP lease change., Friday, May 15, 2020 00:53:36
[DumaOS] DHCP new event., Friday, May 15, 2020 00:53:36
[DHCP IP: 192.168.1.6] to MAC address 9a:32:2c:f2:2e:8c, Friday, May 15, 2020 00:53:36
[DumaOS] Cloudsync DPI result 'false','All mirrors are down', Friday, May 15, 2020 00:48:19
[DumaOS] R-App store cloud sync failed, Friday, May 15, 2020 00:48:17
[DumaOS] HTTP download failed with code '404', Friday, May 15, 2020 00:48:17
[DumaOS] Resync R-App store cloud, Friday, May 15, 2020 00:48:17
[DumaOS] Cloudsync Themes result 'false','All mirrors are down', Friday, May 15, 2020 00:48:16
[DumaOS] DHCP lease change., Friday, May 15, 2020 00:44:29
[DumaOS] DHCP new event., Friday, May 15, 2020 00:44:29
[DHCP IP: 192.168.1.6] to MAC address 9a:32:2c:f2:2e:8c, Friday, May 15, 2020 00:44:29
[DumaOS] DHCP lease change., Friday, May 15, 2020 00:44:26
[DumaOS] DHCP new event., Friday, May 15, 2020 00:44:26
[DHCP IP: 192.168.1.6] to MAC address 9a:32:2c:f2:2e:8c, Friday, May 15, 2020 00:44:26
[Internet connected] IP address: 47.188.197.221, Friday, May 15, 2020 00:41:18
[DumaOS] DHCP lease change., Friday, May 15, 2020 00:38:18
[DumaOS] DHCP new event., Friday, May 15, 2020 00:38:18
[DHCP IP: 192.168.1.6] to MAC address 9a:32:2c:f2:2e:8c, Friday, May 15, 2020 00:38:18
[DumaOS] DHCP lease change., Friday, May 15, 2020 00:38:17
[DumaOS] DHCP new event., Friday, May 15, 2020 00:38:17
[DHCP IP: 192.168.1.6] to MAC address 9a:32:2c:f2:2e:8c, Friday, May 15, 2020 00:38:17
[DoS Attack: SYN/ACK Scan] from source: 93.125.99.58, port 443, Friday, May 15, 2020 00:37:36
[admin login] from source 192.168.1.2, Friday, May 15, 2020 00:36:20
[admin login] from source 192.168.1.2, Friday, May 15, 2020 00:36:18
[DoS Attack: TCP/UDP Chargen] from source: 74.40.74.41, port 53, Friday, May 15, 2020 00:29:45
[DoS Attack: TCP/UDP Chargen] from source: 74.40.74.40, port 53, Friday, May 15, 2020 00:29:45
[DoS Attack: TCP/UDP Chargen] from source: 74.40.74.41, port 53, Friday, May 15, 2020 00:29:41
[DoS Attack: TCP/UDP Chargen] from source: 74.40.74.40, port 53, Friday, May 15, 2020 00:29:41
[DoS Attack: TCP/UDP Chargen] from source: 74.40.74.41, port 53, Friday, May 15, 2020 00:29:39
[DoS Attack: TCP/UDP Chargen] from source: 74.40.74.40, port 53, Friday, May 15, 2020 00:29:39
[DoS Attack: TCP/UDP Chargen] from source: 74.40.74.41, port 53, Friday, May 15, 2020 00:29:38
[DoS Attack: TCP/UDP Chargen] from source: 74.40.74.40, port 53, Friday, May 15, 2020 00:29:38
[DumaOS] DHCP lease change., Friday, May 15, 2020 00:29:15
[DumaOS] DHCP new event., Friday, May 15, 2020 00:29:15
[DHCP IP: 192.168.1.6] to MAC address 9a:32:2c:f2:2e:8c, Friday, May 15, 2020 00:29:15
[DumaOS] DHCP lease change., Friday, May 15, 2020 00:29:13
[DumaOS] DHCP new event., Friday, May 15, 2020 00:29:13
[DHCP IP: 192.168.1.6] to MAC address 9a:32:2c:f2:2e:8c, Friday, May 15, 2020 00:29:13
[admin login] from source 192.168.1.2, Friday, May 15, 2020 00:28:22
[Internet connected] IP address: 47.188.197.221, Friday, May 15, 2020 00:26:18
[DoS Attack: TCP/UDP Chargen] from source: 80.82.77.245, port 54255, Friday, May 15, 2020 00:18:35
[DumaOS] DHCP lease change., Friday, May 15, 2020 00:13:37
[DumaOS] DHCP new event., Friday, May 15, 2020 00:13:37
[DHCP IP: 192.168.1.6] to MAC address 9a:32:2c:f2:2e:8c, Friday, May 15, 2020 00:13:37
[Internet connected] IP address: 47.188.197.221, Friday, May 15, 2020 00:11:18
[DumaOS] DHCP lease change., Friday, May 15, 2020 00:07:45
[DumaOS] DHCP new event., Friday, May 15, 2020 00:07:45
[DHCP IP: 192.168.1.6] to MAC address 9a:32:2c:f2:2e:8c, Friday, May 15, 2020 00:07:45
[DoS Attack: SYN/ACK Scan] from source: 93.125.99.82, port 443, Friday, May 15, 2020 00:02:53
[DoS Attack: SYN/ACK Scan] from source: 93.125.99.82, port 443, Friday, May 15, 2020 00:00:05
[Internet connected] IP address: 47.188.197.221, Thursday, May 14, 2020 23:56:17
[DumaOS] DHCP lease change., Thursday, May 14, 2020 23:55:00
[DumaOS] DHCP new event., Thursday, May 14, 2020 23:55:00
- Netduma-FraserNetDuma PartnerIf you provide a static IP/IP reservations for some of the affected devices in LAN Settings do you still see the issue on those devices?
- David_allen09Aspirant
Seeing how every DHCP lease event causes the router to crash and reboot, I dont think setting static IPs is going to fix that. For some reason, everytime the Lease renews, I suddenly get a ton of DOS attacks and a router shutdown and reboot
- Netduma-FraserNetDuma PartnerWait so the entire router reboots itself when this happens? If that's the case try plugging the power directly into a wall outlet, if it continues try another power adapter. If it's still a problem then I would recommend getting the router replaced.
