batesy's avatar
batesy
Tutor
Jul 18, 2018
XR500 has WAN IP but reports being disconnected
Hi
I use a bridge from my ISP's router to my current router but the XR500 is refusing to do the same. It displays the correct WAN IP 51.x.x.x. I've reconnected my old router to post this because I can't make any sense of this. The XR500 auto-detects the same IP and DNS as my current router but that's about it. I've tried to reset it multiple times and setting it up both with IPV6 and IPV4 but to no avail. Despite recieving the correct IP/DNS/etc it simply displays "not connected".. Could the WAN port be broken? I don't even know anymore..
  • Put the MAC address of your previous router as the MAC of your XR500 and see if that resolves the issue
  • oh and I've tried using both the xr500's mac and my own computer's mac adress to no avail
    • Netduma-Fraser's avatar
      Netduma-Fraser
      NetDuma Partner
      • batesy's avatar
        batesy
        Tutor
        yup.. that worked. Should've thought of that.. thank you for your help
