jrwalte's avatar
jrwalte
XR500 horrible local wifi performance
I have an issue on my network I can't figure out. It started with having issues streaming local media content from an Emby server to wifi clients. Anything above 5mbps would have constant freezing. I thought it was an Emby issue, but it turns out it looks to be my router.
I tried to transfer a file from server to my PC and something weird is going on. At my PC I will get a wireless link of 780/650 on 5 band and 144/144 on 2 band. If I try transferring a file from server to PC, I stay around 500KB or less. I also see the same issue if I connect to the 2G band. If I transfer the file wired, I hit around 95MB, so it isn't a throughput issue of server or PC. And a speed test on the PC over wifi I get 50MB, so I would think my wifi has the throughput as well.
I also never experience issues with internet traffic. All devices on WiFi have no issues with streaming services, and I know they are going above 5mbps. I can achieve speed tests on those devices of over 300mbps.
It's been nothing but problems with this router model it seems. In the past, it was constant wifi crashing and only a reboot would get devices reconnected. I RMA'd that device and had this new one for over half a year now. I didn't have this issue with Emby in the past on this new router. I used to be able to stream direct so I was hitting up to 70mbps.
Things I've tried:
rebooting all devices
updated XR500 to latest firmware 2.3.2.114
disabled all features of QoS
checked wireless channels I'm on and no one else is. Tried changing channels just to see.
Is there some setting in DumaOS I'm missing that would only throttle local network traffic when over wifi?
  • Sorry to hear this!
    We have heard of a couple of issues with devices communicating with local file servers over wireless with the XR range, so Netgear are looking into a fix for this.
    Is the file server connected to the XR via wired or wireless?
    What kind of hardware is the Emby server running on?
    There is a beta version of the XR500 firmware available that you could upgrade to and try, though we'd definitely suggest factory resetting after upgrading firmware as it clears out any low level code left over from the previous firmware.
    You can find the beta firmware here:
    https://community.netgear.com/t5/Nighthawk-Pro-Gaming-DumaOS-3-0/New-Firmware-v2-3-2-120-XR500/td-p/2071196
    • jrwalte's avatar
      jrwalte
      The server is wired. I can achieve 95MBps on a wired file transfer test. It's running Server 2012.
      I'll try the firmware update and reset.
      • Netduma-Liam's avatar
        Netduma-Liam
        NetDuma Partner
        OK sure thing, thanks for letting us know.
        Keep us updated with how you get on after the firmware upgrade.
