Rob-xr500
Apr 12, 2021Tutor
Xr500, I have an issue with my Nat type on call of duty.
Looking for help with Moderate NAT type on call of duty warzone, i am having issue with joining friends private chats and finding games when the party leader.
My setup is Sky home hub connected to XR500.
Internet speed is 52mbps. QOS set at 15% on Playstation 5, there is 2 playstation 5's connected to the system but online play COD on one so not sure is that one has the same issue.
I have tried wired and wifi but still the same moderate NAT type.
When i first set it up the NAT type was open but that lasted a couple hours been moderate since. so i think is down to having a double NAT? any recomendations?
Sky Hub can not be put into bridge/modem only mod.
Any help wuld be much appricicated.
Have you tried putting the xr500 into the sky hub's dmz?
- No havenât tried that. Just put xr500 WAN IP into dmz on the sky router?
Will try that in the morning will let you know how it goes. Thanks for the reply đ - Hi just tried it still have moderate NAT type đ©
you might need a reboot after changing it.
you can also check through the dumaos optimal settings guide
