usermac
Jan 25, 2019Luminary
XR500 inaccessible cumulative update bug
I am quite surprised there is no mention of this bug on this forum but if you reinstall your windows 10 or download cumulative update KB4480116 or onwards you will not be able to acess local IP adresses or at least for some people. At first it was just if you was useing the Windows EDGE BROWSER but now it is affected on all at least for me that is.
I am unable to connect to my XR500 this is most frustating as I want to turn GEO FILTER OFF!
The work around that microsoft has issued does not work for me either. Not sure what else I can try
| After installing KB4480116, some users report that they cannot load a webpage in Microsoft Edge using a local IP address. Browsing fails or the webpage may become unresponsive. |
- Netduma-FraserNetDuma PartnerThat's very odd, doesn't sound like a router issue though. If you disable your PC firewall can you connect? Also can you connect using routerlogin.net?
- usermacLuminary
Nothing works for me I have tried firewal aswell the update broke acess to all local ip adresses.
see this link this is my problem
https://borncity.com/win/2019/01/18/windows-10-network-bug-in-all-versions-fix-are-planned/
In the mean time no acess to XR500 not good at all as the solution that microsft offer as a fix does not work at least for me it does not.
- Netduma-FraserNetDuma PartnerSet a static IP on the PC and then try then
