Username5's avatar
May 27, 2018
Xr500 include high ping filter?
The netduma used to have a filter for high/laggy ping players. Does this version of DumaOS still include it aside from the Geofilter?
  • Are you referring to ping assist? If so that would still only get you a server under your ping limit, not block players from joining the server. That will be coming.
    If you're referring to Deny & Allow then yes that is present on the XR500.
    • Username5's avatar
      Username5
      Tutor
      Thank you. My main concern before buying is for example..
      Intentionally laggy player joins destiny game...
      Destiny compensates all other players and makes it a terrible game.
      Not certain they do this but seems likely with how inconsistent the game is.
      So I would want to filter all bad pings.
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        Destiny uses a hybrid system so you could block those players but they may then connect to a server that you connect to. Though as you're closer to the server you have the advantage.
