mahobbs's avatar
mahobbs
XR500 Media server bug v2.3.2.66
Hi
Is anyone else having problems with media server functionality on the xr500 running the latest .66 release.  I had no problems with it under the previous release but it just does not work reliably under .66.
I am presently sticking with the previous release which is a pain as I can't take advantage of security patches.
I have logged the defect with Netgear, this is a new device, but despite having been looking at it for 3 months they have made no progress. Very disappointing.
Thanks
  • I am having the same trouble. Server is visible but when trying to read or play a file just keeps loading with no successes. Only started happening after latest patch
    • Xpunker1's avatar
      Xpunker1
      Initiate
      My firmware version is v2. 3.2.114 and Im have the same media server issues
      • mahobbs's avatar
        mahobbs
        Thanks guys, good to know that I'm not the only one.  My failure mode is exactly as described above, serving files behalves eratically and if a track does appear available it will time out if you try to play it.
        Also useful to know .114 also has this issue, I won't bother spending many hours trying it.
        I'll keep pushing the support case and update re .114.
  • Yes I have issues since this update too.  My mkv files will not play anymore on my Apple TV.  I am going to try to install older firmware version back on the router
